fuse box help
fuse box help
installing an amp on a 2014 SGS I blew a fuse and upon going to replace I noticed several things (this was a recent used bike I purchased and so this would have been how they had it set up)...
the main battery amp actually had a 25 A fuse but it looks like it calls for a 5. as you see in the picture I replaced with the proper 5A but am curious if there is some reason the prior owner would have had a 25A in it, other than laziness? should it in fact have the 5A as indicated on the diagram?
also notice no cooling fuse or relay...obviously I need to correct this, but also notice there are no metal contacts in the slots, and the one spare slot just has a metal contact on one side. is there a way to replace just the contacts or will I need a whole new fuse box?
I would guess that the previous owner blew the Batt fuse, didn't have a spare 5A so he used what he had, 25A. Dangerous thing to do. The reason that they spare 5Amp fuse has a contact on only one side is that the fuse is a spare. The circuit is not. They do sell fuse terminals. You can do an Internet search for them.
that does bring up another question....i did notice behind the panel there was a connector that looks identical to a tender pigtail connector. i was curious what this could be for? i didn't look to see where it goes to. i do have my own tender pigtail attached but its tucked up in a different location.
