2013 Tri Glide Inner Fairing wiring issues
I hope somebody can help me sort this little dilemma I find myself in, bought a statuary write off 2013 Tri Glide and went about sourcing another frame and changed everything over with a couple of plugs coming from the fairing harness that I just can't seem to locate what purpose they serve, I should say I may know what 2 do but am not sure, looking from the front on the right hand side there are 3 vacant plugs with these wires first plug has Orange/Red Stripe wire with a Black wire, second has a Blue/Violet Strip with a Black and the third has Black/Grey Strip with a Black, I think one is for heated grips and another maybe Air Temp, doesn't seem to affect the bike running but if anyone can help it would be appreciated.
Thanks but I have it printed out and been searching for that last pair of wires and can only find reference to that Black with Grey Strip going to the TMAP Sensor I guess is the map sensor on the intake,and TGS whatever they are, I gather the TGS maybe the twist grip sensor but I haven't got any connections from the throttle left over,there only 2 pair of three coming from the throttle to the connector at the triple tree, the only thing I think it might be is for the cruise if fitted,only a guess.,I digress I thought somebody may be able to enlighten me as to what they plug into, seems strange having connections to nowhere.
