New 1 wire blinkers to 2 wire bike (no flash)
This is probably a dumb question but I know very little to do with electrical.
I bought these blinkers for my 99 fxstc,
https://www.ebay.ca/itm/Chopper-Bobb...T-N4X7UH32y5Ik
..and they have one wire. When I connect the lamp wire with the positive on the bike and then ground the blinker on the bike the light will come on but does not flash.
Can anyone tell me why they will not flash? I can try to provide more info if needed.. I'm fairly certain the original blinker is one filament and the new ones are also one filament.
Much 'electrical' stuff is actually mechanical! In the case of your lights they use that one wire for power, and rely on a ground return through the light body and other bike hardware, to complete the electrical circuit. I suspect you need to use that single fitting screw to add an extra wire, using an eyelet, then secure the other end to a suitable point on your bike, such as an existing ground fixing point.
thats what i'm doing in the video, the old one is the first to ground in the video, then i do the same thing with the new and it just comes on.
at first when the new light was still attached to the signal light body i grounded to the bike (fender rail) then i tried it like shown in the video, where i have the old attached to the purple and the new attached to the purple wire, then i take the old and touch it to the black wire and it blinks, then i take new and touch it to the black with and it comes on solid
