FXD 2002 Engine dies, maybe Run/Off-switch.
Hi!
I just got an 2002 FXD Super Glide that shuts off when I ride, I can't see any pattern it seems to shut off completely random. When it shuts off I still got power in the electrical system, the speedometer and turn signal still works (all I've manage to check because it has shut off in hectic traffic). So it's just the engine that shuts off, and when it shuts off I flip the Run/Off-switch and the engine starts up again. Im kinda green when it comes to the electrical and my knowledge is limited so I don't really know where or what to look for.
Do you guys have any idea what the problem might be or know where I should look for information?
P.S sorry for any weird spelling, english is not my native language.
Have you just tried to just hit the start switch when it shuts off? I would start looking at the ignition switch, these are prone to go bad (just cleaning the internal contacts may fix it) but the run/stop may be starting to go bad. . . if you try to just hit start without moving the run-start switch you can isolate the run/stop switch out of the equasion.
Im gonna take a look at the ignition tomorrow, will let you know how it goes.
When I hit start without moving the run/off-switch the starter tries to start the engine, yesterday I stopped the bike and waited a bit twisted the throttle two times (don't even know if that do anything) and the bike started in a kinda sluggish way. So I guess it's not an electrical problem?
But everytime the bike shuts off and I flip the run/off-switch it starts immediately, it's like the run/off-switch reset something.
Everything is so confusing and I can't recreate the problems so it's really hard troubleshoot. I need to ride the bike (no complaints there ) to look for the problem, sometimes I can ride for five minutes and sometimes five days until the problem occurs.
On the fxd the ignition switch isn't able to be disassembled as it is in the Softail, check the connections on the ignition switch and the continuity of the connections with the switch in the different positions, follow the service manual wire diagrams to tell what is supposed to be connected with the switch in each position. For softails if you remove the switch there is a snap ring on the bottom, be aware of the spring loaded contacts, remove the snap ring and remove the bottom plate, clean the contacts and use dielectric grease during reassembly.
ronster2
05-20-2014 09:46 AM
