Led Accessory Headlight light
I bought a Harley LED headlight for my 2017 SGS. Plug and play works great. It has a light shaped like the HD emblem at the top. I would like the light to come on when the ignition is switched to accessory. It will come on when the bike is switched to accessory and i hit the brake or when the bike is on. Any help is appreciated.
That light is in the center of the crossbar in my reflective day timer headlight. I found mine is connected to the extra wire at the plug on the headlight, and connected it to the extra wire inside the fairing that was wrapped around the wiring that the headlight plugs into. I have the auxiliary passing light kit installed that allows me to run the passing lights while on high beam. Now that center bar & shield LED light is on when I am on accessory, or the headlight is on.
jim76hd
03-19-2011 04:42 AM
