How to shut alarm off so I can change battery and it is annoying
08-26-2018, 04:11 AM
Can't shut annoying alarm off so I can change battery need info on this please
08-26-2018, 05:03 AM
Have the fob with you, turn on ignition, pull maxi fuse. .you're good to go
08-26-2018, 05:40 AM
Or turn ignition on, with either the FOB present or with the code, and then simply disconnect the negative battery terminal, then positive, and remove the battery.
08-26-2018, 08:07 AM
This stuff is all in the owners manual...
harleyHBX
07-31-2017 09:53 AM
doug62
12-08-2015 09:00 AM
Hunter1979
08-03-2015 09:27 PM
Rocker_Dan
12-21-2013 11:32 PM
jd140400
03-20-2008 11:13 PM
