Help needed to find Accesory Power on an '18 Heritage
Old 08-19-2018, 01:39 PM
FrankEV's Avatar
FrankEV
FrankEV is offline
Default Help needed to find Accesory Power on an '18 Heritage
Need to locate a swithed 12v power source near or under the seat of an '18 Heritage. No H-D accessory cable adaptors available that I can find.
I have the service manual and have searched through the wiring diagrams but cannot determine where a suitable sorce of switched accessory power is located.
I'm installing an INNOVV K2 camera system. it has a black/ground wire, a Red/unswitched power from the battery and a third yellow wire that has to be attached to a switched 12v accessory power source.
The black and red were no trouble to find suitable connection points. I tried attaching the yellow to the rear tail light circuit but the yellow has a 5v output that keep the tail light lit even when the ignition switch is off.
I found another switched power source in the connector used for attaching the street tunner to, but it caused my battery to die.
I'm usually fairly good at electrical work, but I can not figure this out. INNOVV instructions and support are no help.
Please don't just show me in a diagram, but if you can show or tell me the physical location of the wire or connector I should be looking for.
Old 08-19-2018, 04:14 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is offline
Do you see any orange wires with a white stripe under your seat??( or anywhere for that matter). On my RK the orange with white stripe is a switched power source. I used it on mine and friends bikes. You can test to find out.....
Old 08-19-2018, 05:21 PM
j_bee's Avatar
j_bee
j_bee is offline
https://www.harley-davidson.com/stor...ion-update-kit
and fitment instructions,
https://serviceinfo.harley-davidson....1?locale=en_US
which even if you don't go for the kit ( which I think is overly complicated with inordinately long wiring for most uses ) may help you choose the correct place to tap into. See connector 325b in diagram.
Old 08-19-2018, 05:44 PM
FrankEV's Avatar
FrankEV
FrankEV is offline
Thanks,
Got to the same #325 connector from info given in reply to another post under the Softail section.
I think that is what I'm looking for. Will probably just tap into the R/Y wire near this connector. The R/Y is the switched power according to the manual for the '18 softails.
Very much appreciated.
wildrooster
08-23-2020 12:38 PM
AndyFL
Electrical/Lighting/Alarm
04-20-2018 08:49 PM
knitski
Audio Systems
05-24-2017 12:21 AM
star2nv
Audio Systems
17
03-30-2015 06:39 PM
plysat
04-20-2008 09:24 PM
Quick Reply: Help needed to find Accesory Power on an '18 Heritage
