2014 HD (International) FLHX complete lighting system conversion
Hi everyone,
I have a 2014 FLHX International sepcs and need to convert the complete lighting system on my bike, this includes:
Head light from halogen to LED
Front turn signals to LEDs as well as making them function as running / turn lights ( currently they run as turn signals only)
Rear tail lights (Stock is LED but not bright enough) also to function as running / brake / turn lights.
I would really appreciate it if anyone can give me details on which are the best LEDs in the market / aftermarket as well as all the other parts needed (i.e wires..etc) and where I can purchase them from (Online) to complete this project.
Thanks in Advance..
Thanks in Advance..
As your machine is an HDI model you only have the 2 wires (turn/ground) going to the front turn signals, I believe that the main harness is the same so you should have the wires at the connector going to the front. You also have the little marker light in the headlamp that if you don't have the wires in the main harness to supply to the turn signals you can draw power from the headlamp marker, you will also need to get the domestic version of the turn signals as they have the 1157 sockets rather than the 1156 sockets.
Hi guys, a quick follow up on the same issue,
I've contacted Custom Dynamics and they have given me some great options for the front parts (Headlight / Turn signals). Unfortunately, they don't have the brake lights for HDI as the OEM part comes as a whole unit.
I really liked the options they have given me for the front units. However, I need a rear unit to match the front parts.
Any suggestions ??
Any suggestions ??
Any suggestions ??
Any suggestions ??
