Help with Fuel Sender Resistor ID
I'm upgrading the low fuel sensor on my 2014 Sportster 1200 Custom to a fuel level sensor and supposed to put a jumper wire on the fuel sender resistor connector under the seat but instructions lack any figure showing that step. Is this it?
Well, it's a short if anybody's paying attention. Found that the jumper wire pins that HD provides in the kit aren't long enough to make connection to the other part of the relay as shown in the above photo so have to run the jumper without the pin housing. Harley is lacking terribly with their instructions as well as the parts quality. Wish I had just bought the low fuel sensor replacement and been done with it.
AjaBra
10-23-2020 02:18 PM
knucklehed
08-01-2014 05:50 AM
