Tapping Wire for Ignition Power
Old 04-20-2018, 12:47 PM
AndyFL's Avatar
AndyFL
AndyFL is offline
Default Tapping Wire for Ignition Power
On a '15 RGS, where is a good place (under the seat) to tap for ignition power? What color wire should I look for? I'm using a Posi-tap and don't want to connect wire directly to the battery positive terminal. BTW, I own an electrical manual but lend it out and don't have it in hand right now. It's Thanks in advance guys.
Old 04-20-2018, 06:28 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is offline
On my 2011 FLHR, I used the wire heading back to my rear signals. Look just behind your battery for the plug and find the orange wire with white stripe, that is/should be a switched power wire. I then used the bolt that holds the ECM tray down for a ground. Hope this helps....
Old 04-20-2018, 08:49 PM
AndyFL's Avatar
AndyFL
AndyFL is offline
Thanks hammerhead, I was able to locate it with the help of the manual. On my 2015, it's a red & yellow wire on a capped off grey plug behind the left side panel.
HDJIM1158
10-10-2018 02:28 PM
star2nv
Audio Systems
17
03-30-2015 06:39 PM
Randy Marsh
03-27-2015 07:07 AM
Rustybeater91
05-11-2014 09:00 AM
Foodog
09-29-2010 11:18 AM
Quick Reply: Tapping Wire for Ignition Power
