No Horn No Speedo No signals No Brake lights!
Please tell me this is a simple fix. 2005 Road King Classic, all original. I replaced the 15 amp fuses (on the right side under the cover), I checked the relay under the seat and I changed the batteries in the key fobs. I replaced the rear light bulb.
Alarm makes all signals work, but nothing at all when I press the signals. Bike rides great... just need to figure out what relay/ fuse this is and change it.
If it were a ground, I think that the alarm lights would also not work, but they do... because of all the same things, it has to be a relay?
Thanks everyone and anyone!
-Jack
-Jack
Are you sure all the fuses are good? Sounds like an Accessory fuse blown. Did you look under left side cover as well? Right side is only EFI system fuses, rest are under left side.
Accessory fuse is likely blown, common areas to check if it blows again, are pinched wires at handlebar controls, as well as damaged wiring harness under rear fender.
Jack Antic (08-25-2017)
Hillbilly13
05-11-2019 09:59 AM
TReaper
Electrical/Lighting/Alarm
11-18-2014 12:16 PM
berkatz23
09-27-2007 06:11 AM
97chopper
07-12-2007 02:35 PM
