starter hesitation
Old 08-27-2017 | 02:06 PM
mlrailguy's Avatar
mlrailguy
Finally got the primary cover off and find this. The gear is easy to push back in, guess I'll soon see what is going on inside.
Old 08-27-2017 | 03:16 PM
mlrailguy's Avatar
mlrailguy
So the curved piece is supposed to be underneath and not sitting in there sideways?
Old 08-28-2017 | 05:26 PM
Zanthamos's Avatar
Zanthamos
What gear are you talking about? If there was supposed to be a picture attached to the post it isn't there.
Old 08-28-2017 | 05:34 PM
skid_pimp's Avatar
skid_pimp
I can see them fine
Old 08-29-2017 | 10:45 AM
6530mask's Avatar
6530mask
The pinion gear should be completely clear of the ring gear when the electric starter is disengaged.
Be careful pushing/pulling that pinion gear - you could inadvertently engage the starter. If you haven't done so, it's a good idea to isolate the battery before working on the starter.
Old 08-29-2017 | 11:32 AM
mlrailguy's Avatar
mlrailguy
yep, all disconnected, thanks.
Went to local battery/starter shop. They didn't have the rebuild parts in stock, so got them ordered. The curved washer that sits under plunger, had gotten twisted a bit, which caused it to come up alongside the plunger, and that is what was holding the starter gear engaged to flywheel.
I must have over tightened the battery cable to starter and spun the piece inside. ? Weird, that it was still starting because that had been 3 or 4 weeks ago.
Also found the crimp on fitting at battery (positive cable) was loose enough to be pulled off easily.
wideglideCVO
07-12-2016 10:54 AM
DEric24
Electrical/Lighting/Alarm
07-03-2015 08:53 AM
stephtell
EVO
13
03-02-2015 09:20 AM
bugzapper
08-30-2014 12:01 PM
sportyfrahm76
05-31-2012 01:10 AM
Quick Reply: starter hesitation
