won't start, good battery no dash lights
Some idiot, not excluding myself, connected the battery charger reverse polarity. I know you dumb a__. The ironic part is I have been an electronics technician since 1969. I DO KNOW BETTER.
Any way, It would not start before this stupid move, unless I played with the turn signal switches. I made sure the battery was removed and the charger connected correctly and with a full charge. I then tried the security system alarm override pin reset. I went through the guide and when I put the last pin number in and pressed the right turn signal switch on more time both signals would flash 3 times pause and do this over and over again until I held both switches for 2 seconds , then 2 more seconds and 2 more seconds, the turn signals would stop flashing but I have not been able to get the dash lights, fuel pump or any other functions to act right. I sure could use some suggestions here. I know there will be questions and I will answer them as soon as I possibly can. Even if I have to go to the stealer.
Thanks much Guy's and have a great day,
Ken
Ken
CMYoungston
08-25-2011 12:49 PM
