Anyone recognizes this? Installed Daymaker headlight on 2007 Street Bob. Works great. But ... turn signals do not work anymore, no backlight, horn does not respond. When I start speedo is gone as well?
Clone.
Disconnected battery before I started. Reconnected when I was done
Will check fuses, did not do so yet as speedo is back to life when shut off engine and hazard lights flash when alarm engages.
Checked fuses first, found a broken one. Before replacing double checked wiring around headlight and found issue. Piece of isolation missing on one of the connectors. Taped it, replaced fuse and everything works as designed.
