Motoscope mini install help needed!
I am installing the motoscope mini speedo on my 1995 Sportster. I have almost all of it wired up except for Tach and Turn signal cancellation. The help I am needing is
1) I need to know the number of impulses transmitted from the speedometer sensor per wheel turn on my stock sensor. Also I am assuming since I am using my factory sensor I need to measure the circumference of the rear wheel and not the front?
2) My 1995 Sportster 883 didn't come with a tach. I am wanting to wire up this feature. I need to know how to find this.."Leads to the negative pole
(clamp 1 or -) at one ignition coil. In case of a CDI ignition you must use motogadget ignition signal pickup unit (article no 9000001" I am assuming that is one of the two post on my coil? If so how do I know which is which?
Any help would be appreciated. I included a link to the manual.
Thank You
https://motogadget.com/shop/media/do...l_en_2.3_k.pdf
Thank You
natca1
06-19-2011 01:13 PM
