Rear Signal 2006 Dyna Wide Glide Issue
Morning!
Having a rough go with these damn turn signals.
Headlight is Harley Daymaker, tail light is LED.
On this bike for the rear signals it is a single filament bulb that has a run, turn, stop function. I left the signal bulbs incandescent.
Symptom:
Left side functions as it should, run, turn, stop.
Right side, turn only. And the red bulb would just spin and spin in the socket, glass separated from the base. I think this may have caused the issues.
I found the little fancy circuit board Harley uses and I suspect that the connection from the left is broken in the board and therefore not "communicating" with the right for the run, stop function.
Looking at the way the circuits are connected, I am thinking about creating a jumper wire to test my theory when I get home tonight.
Thoughts/suggestions? I already took apart the right side signal and have to replace the socket within.
Damn the luck, just got this Glide running perfect and this happens!
Symptom:
wmclay
07-27-2012 08:09 PM
whitedaddy
07-14-2007 02:31 AM
