poor packaging of battery from JP Cycles
Old 10-14-2016, 12:25 PM
awilson40's Avatar
awilson40
awilson40 is offline
Veteran: Marine Corp
Received 1,510 Likes on 554 Posts
Default poor packaging of battery from JP Cycles
I just received a big bore battery from JP Cycles. They just dropped the original box in a larger box with no additional packing and this is what I got. I notified them and they just said they would make a note of it. Its not cracked and is at full charge after a night on the tender. Do you think its OK to install ?
Old 10-14-2016, 12:34 PM
Mikes145's Avatar
Mikes145
Mikes145 is offline
I wouldn't. Mainly because you paid for a new, undamaged battery and you didn't get that. Tell them to send you a new one and when you get it, you will send the damaged one back and make them pay for the return postage.
Old 10-14-2016, 12:42 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
I wouldn't use that battery. No telling what has happened to it internally.
Old 10-14-2016, 12:54 PM
Cousy's Avatar
Cousy
Cousy is offline
No way I would accept that.
Old 10-14-2016, 05:30 PM
loopie's Avatar
loopie
loopie is offline
if I was JP cycles I would tell you too go away.. you ****ed up.. if the parcel arrived as stated then the damage would have been evident on the box .or on the battery case as shown. Then a simple case off returning it no problem... BUT you then proceeded too fill it with acid too which u just lost the ability to a replacement/refund.. TO me it looks like you filled it then put the cap strip in then dropped the ****er,
Old 10-14-2016, 05:42 PM
nfe's Avatar
nfe
nfe is offline
The problem is that I also had issues with them! They failed to ship an "IN STOCK" tire within 7 business days; even tho I got the bearings I ordered. I found out form an amazing CS rep, that they merged with another 'warehouse' namely Motorcycle-Superstore.com and everything has gone downhill since then. Good luck with them doing anything for you; or for that matter getting a replacement from them. The CS reps have ZERO communication with anyone within 48 hours. As far as I'm concerned, I've written JP Cycles off due to their issues. I didn't post my issues on this site; or I'd link the convo. However as I said; no tire in 7 days, and they kept telling me it'd ship 'today' for 4 days. After hearing that they couldn't gaurantee anything; or hear anything within 48 hours, I pulled the plug on the order... (9 days after placing it).
Good Luck
-G
Old 10-14-2016, 06:02 PM
awilson40's Avatar
awilson40
you are a dick and you just showed your ignorance to boot. Its an AGM battery. you dont fill it with acid. Go back under your rock you troll.
Uncle Larry (10-14-2016)
Old 10-14-2016, 06:05 PM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is offline
I would request a return and order from somebody who knows how to properly package a battery like battery mart IMHO.
awilson40's Avatar
awilson40
Thanks for the suggestion. I did just that and a new battery is on the way at no charge. Mistakes happen, its how you deal with them and try to make them right that defines if you are a good company to deal with.
So far they have done good by me.
Thanks for all your input. I was about to install it and see what happens.
Old 10-14-2016, 07:03 PM
loopie's Avatar
loopie
loopie is offline
whats a matter you yank tosser go cry too mum or your boyfriend
u big girl
Quick Reply: poor packaging of battery from JP Cycles
