headlight upgrade ?
headlight upgrade ?
As a new HD owner I have been shopping for possible mods and accessories I might want. I see Kuryakyn has a super white H-4 headlight bulb.
It seems like a good idea to me but they have a disclaimer that this is for off road only. I assume I can ignore that but I would appreciate any input?
You can use any auto bulb of the correct type, such as H4 which is probably what your bike uses, simply check on-line auto-bulb suppliers, or your local auto parts store. If you are tempted to buy a higher voltage than stock you should consider also using a relay, otherwise you risk cooking your harness. No need to buy bulbs from high-profile brand bike specialists, when similar things are readily available. I've used various brands of bulbs over the years, but do have Trucklites on my Glide.
dports70 (08-13-2016)
Fuel Moto has a good H4 LED replacement bulb... $70, and sometimes on sale. Mine plugged right in, and throws out a lot more light. Not as nice as a daymaker, granted. But it is a lot more affordable.
http://www.fuelmotousa.com/i-2112160...ment-bulb.html
this: https://www.amazon.com/HELLA-HLA-H83...headlight+bulb
I've had no issues in a 7" headlight with overheating. Look for 80/55s also.
