Need 1995 Road King Wiring Schematic
Damn it! Title should have said 1996!
Good morning folks. 1st post here. Thanx for letting me in and thanx in advance if you can give me a hand.
I shoulda bought a service manual for the RK that I picked up for my wife a couple years ago, but I haven't yet. Trying to do a turn light LED conversion. My buddy has a 95 and he put in the conversion bulbs and drove away. I did the same exact thing and I have lights, but they won't flash. Been down this road with my Nomad, so I know where to go. Already have the Badlands Run/Turn/Brake controller (with built-in load equalizer ready to put in, but the colors and the wires don't sync up, so I need a diagram.
Can anybody scan one for me or at least give me the run down on the wire colors for the connectors? This bike has a 6 pin setup vs the 8 pin that they went to in 97.
To express my issues in a different way,
I have my seat off and the right side panel off. There are 4 harness connectors under these 2 areas. The one under the side panel is a black plug about 1 X 1-1/2". It has W/B, B/W, R/W, R, G/W, P/W & B wires. The connector under the seat is the same size, but light grey in color. It has R/W, B/W, G/W, B, W & Pink. The other 2 connectors are much smaller - about 3/4". One is triangular and one is square. They are both black. I won't list the wire colors, because there is no way these are the light harnesses, right? All of these connectors have enviro shields/gaskets on them, like a weatherpak/deutsch/metripak connector. The controller that I bought has an 8 pin connector that is plug and play for all the newer bikes, 97-on, from what I can tell. Here's a pic:
https://www.denniskirk.com/H21030.sk...ad=45712965997
There is no way I can tell which connector on the bike I'm after without knowing the wiring color scheme and I've googled my *** off trying to find a schematic for the 96 Road King.
Anyone out there that can lend a hand, I would greatly appreciate it!
Thanx!
Thanx
Thanx!
Thanx
motogpfan82
Electrical/Lighting/Alarm
06-09-2019 07:57 AM
Hiwaytohell
09-19-2007 08:18 PM
