3 relays: starter, brakes, system
Anyone know the HD part number for these three (identical) relays found in the fuse box of my 09 FLHTCU? One of mine is bad and I'd like to get the part number so I can cross reference at an auto parts store. Didn't see anything about this in this forum or elsewhere on the site, so there 4 prong OMRON relays must be really reliable or I'm the only person to ever ask where to get them. Searching via Google has been hopeless, for once.
Do yourself a favor: if there is a Harley dealer around, go get them there.
I tried the route of trying to cross reference them.
I eventually found a direct replacement for the lighting relay at two different auto parts stores, they were 2 to 3 times the price of the Harley part ( 31595-09 )
Think I found found the new manufacture's part number for the other three, but could not find a cross reference for any with an auto parts store, the ones that seemed to be correct were no cheaper then Harley. The auto parts stores will only guess.
( I believe the one you are looking for is HD part number 31586-07 )
Drair (03-14-2016)
Are you familiar with this parts finder?
You enter the year.
Locate the model.
Then check by part type OR look at the little box to type a description like relay.
Seems to bring up a diagram and lists 3 required as part number 31586-07 at $6 USA dollars each.
The diagrams are nice and can help to "name" parts.
Here is the link:
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
You enter the year.
Locate the model.
Here is the link:
Drair (03-15-2016)
