Light kits LED for the body of the bike?
Look into LED strip lights. The use 12 volt power and can be stuck just about anywhere, under fenders, under the tank, on the frame, etc. You can get single color lights or RGB ones. The only thing is you will need automotive wiring experience, plus know how to solder.
Also, LEDGlow kits are just using strip lights with a high price tag. You can get LED strip lights on Amazon for a quarter of the price.
Budda109 (03-06-2016)
I have been looking at the Custom Dynamics http://www.customdynamics.com/wizard_lights_color_changing_led_accent_lights.htm
Thoughts??
Thoughts??
Stay away from LEDGLOW! After doing a meticulous installation where I removed the fenders and tank to hide all the wires, I connected everything and tucked the excess wire behind the oil bag just like in the video. I tested everything and it was working great. I took the bike for a ride and when it got dark I was super excited to show off my new lights. I used the app to start up my pre-programmed lights and only one zone turned on. As my friends watched I changed to a different setup and the lights went out. That was it, the controller died. I removed the seat and the light on the control box was off even though the power to the bike itself was fine. I checked and replaced the fuse but that was not the problem. I gently tugged the wire harness out from behind the oil bag and discovered that 3 of the wires had lost their connectors and bare wires were making contact and shorted out the control unit! I can't understand how these wires worked themselves loose! The quality of this kit is very poor and the design of the control box is so bad that it will short out without burning out the fuse! LEDGLOW refuses to replace the $70 control box even though they agreed to replace the faulty wires.
[+1 for xkglow as well. 4 lights out in 1year. total junk.
QUOTE=Covenant;15333406]Stay away from LEDGLOW! After doing a meticulous installation where I removed the fenders and tank to hide all the wires, I connected everything and tucked the excess wire behind the oil bag just like in the video. I tested everything and it was working great. I took the bike for a ride and when it got dark I was super excited to show off my new lights. I used the app to start up my pre-programmed lights and only one zone turned on. As my friends watched I changed to a different setup and the lights went out. That was it, the controller died. I removed the seat and the light on the control box was off even though the power to the bike itself was fine. I checked and replaced the fuse but that was not the problem. I gently tugged the wire harness out from behind the oil bag and discovered that 3 of the wires had lost their connectors and bare wires were making contact and shorted out the control unit! I can't understand how these wires worked themselves loose! The quality of this kit is very poor and the design of the control box is so bad that it will short out without burning out the fuse! LEDGLOW refuses to replace the $70 control box even though they agreed to replace the faulty wires.[/QUOTE]
