Electrical?
Electrical?
I recently installed an LED light kit and replaced my battery in my 2008 Electra Glide. I took it to a local because I thought I may have damaged something while hooking up the LED lights, because after I installed them, the brake/taillight stopped working. Turned out the bulb just blew. The day I got it home from the shop, the battery died, and I replaced it. Since I installed the battery, my gauges are jumping up and down, and my volt meter is extremely high, to the point where its almost all the way over to the right. The engine light will come on eventually, but it will run fine the first 30-45 minutes or driving. Then it seems like it starts running really choppy, and has a loss of power. Especially in first gear. I can crank the throttle all the way back, and it just sputters. What could be causing this? Any help would be appreciated.
