Sealed beam to H3 driving lights
This may have been covered before but I'm thinking of converting my sealed beam lights to H3 driving lamps on my '00 Fatboy and was wondering what it entails to doing so? My concern would be the ground for the H3 bulb? Unless the new H3 lamps have a ground incorporated on it as to use the existing ground wire inside the lamp housing. Would that be the case? And what/where would you recommend getting these from? I've looked at Amazon and JP cycles and they both have positive reviews. Thanks
Chances are you can get a set locally from a shop. Probably can get some that are take off parts that look new but cheaper than either of those places. And help out a local shop while you are at it. You can probably even get the one's with 881 bulbs in them. You can actually get a good replacement bulb for 881. I haven't seen many h3's that are worth a damn.
