self canceling directionals won't turn off 1996 softail
As the title states they work fine but won't turn off unless I cancel them manually. They worked fine for the last three years I've owned the bike and the only thing I've done differently as of recent is take the tank off and the dash off to do intake manifold gaskets. The speedo works fine so I'm ruling out speed sensor as I assume they run off that to know when to cancel. Best I can find here is check the connector the goes to the dash cause maybe I didn't push it all the way in, well I went back and disconnected then reconnected all the connectors. I'm not saying they stopped working after the manifold gasket job but when I noticed they started staying on it was after doing the gaskets maybe 2 weeks prior. Any input would be helpful thanks.
1996 heritage
1996 heritage
1996 heritage
1996 heritage
Good info. I'm gonna check the connections and if it looks good I'll look into replacing it. Gatta start somewhere
flhrc2009
Electrical/Lighting/Alarm
06-12-2020 02:43 PM
jpbutler1983
08-21-2015 06:01 PM
Shelley Shumaker
09-12-2012 08:06 AM
