I have a 2010 ultra and when the ignition switch is turned to the on position the the bike starts (no starter switch required) - to add to this, with the bike running you can hear the starter engaging. Any ideas where to start trouble shooting this one?
To answer Tshelf's question - It wont run with out the fob near it - good, I cant produce the same problem when the start run switch is in the off position - good. Bars have not been changed yet however, I have them in the shop..
Ok, now as Harleycruiser pointed out try another starter relay (it failed internally) Id bet thats it. But if not there is a short in the starter button in the switch housing. But Id start with the relay first, easier to get to and test.
All - thanks for the tips - ended up being the a stuck starter switch. A perfect time to pull all the stock equipment to install my mini apes, - can't wait!
