Aux./passing light bulbs
04-14-2015, 03:50 PM
I've got a blown bulb and am looking for a brighter alternative to the stock 881 style bulb. It appears that a 898 bulb will fit and is a 37 watt bulb as opposed to the 27 watt 881 and also draws an additional 2 amps. Has anyone had any experience with a higher watt bulb. I'm concerned about possible excessive heat and wire damage. Thanks.
04-14-2015, 04:47 PM
I put 38's in mine with no problems, been mabe two years
04-14-2015, 04:58 PM
Ditto ... I put 37.5 bulbs in mine ( 4 years ago ) and they're still doing the job with no problems what so ever
04-14-2015, 05:57 PM
What bulbs are you using? Are they the 898s?
04-14-2015, 05:59 PM
mine are the par 35 style ,, but the higher wattage did not hurt the switches , or wiring any
04-14-2015, 06:12 PM
par 35 are sealed beams...correct?
04-14-2015, 06:29 PM
yes they are ,, mine is a 2005 ultra classic
04-16-2015, 06:52 AM
OK thanks, I'll give the 898's a try and let ya'll know if anything blows up.
BUZZBEER
Electrical/Lighting/Alarm
12-07-2009 01:15 PM
metalheart
09-08-2009 10:35 AM
mca1989
05-20-2009 03:22 PM
Stash
12-22-2007 09:15 PM
morton78
09-15-2007 04:51 AM
