module
Old 04-07-2015 | 01:09 PM
wildhog7's Avatar
wildhog7
Default module
My Run, Brake,Turn signal module I think is bad .Reason onj one side everthing works and on the other side my turn signal works and Brake works but not my running light is there any fix or check ? I already replaced the bulb
Frank
Old 04-10-2015 | 07:05 PM
ShadyLurker's Avatar
ShadyLurker
Rule out the tsm before you change it. It's a non returnable part. I got burned today....
Old 04-10-2015 | 08:20 PM
Harleycruiser's Avatar
Harleycruiser
Frank
What year, type bike? What bulb did you put in, where did you get it?
Old 04-11-2015 | 08:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
A lesson learned here, do not troubleshoot electrical problems by changing parts.
The motor company has made a fortune selling starters this way...
OP:
In addition to model and year bike, we need to know if you are using any aftermarket electronics for the turn signals, brake lamp.
Old 04-13-2015 | 10:54 AM
wildhog7's Avatar
wildhog7
Default Module
The year is a 2005 Road King Custom the the Module is from Harley
Old 04-13-2015 | 06:34 PM
im's Avatar
im
[QUOTE=wildhog7;13893061]My Run, Brake,Turn signal module I think is bad .Reason onj one side everthing works and on the other side my turn signal works and Brake works but not my running light is there any fix or check ? I already replaced the bulb
You say it is for a 2005 Road King Custom.
Trying to decipher:
One side is OK ..meaning the run, turn and brake (R/T/B) are 100% functional.
The other side is missing the running light...so brake and turn function correctly.
You mention changing but No mention of you removing the bulb, reviewing the bulb and also the socket.
There is no mention if the bulb in the socket is LED or other?
For example a halogen bulb would burn the module.
We have no history and no idea of the exact module.
For example some folks changed the single filament rear turn signals with the dual filament front signals but then later added a R/T/B module. This alters the wiring and could translate to a loose wire, incorrect bulb application or similar..Some modules require LED bulbs only or they will burn the module due to the amp draw if a regular bulb is used..
I will guess that you compared the bottom of the bulb with the inside of the socket and that you have removed the module from the application in order to isolate the problem.
sportyguy69
04-29-2013 06:02 PM
3wheelEd
Electrical/Lighting/Alarm
07-25-2011 10:03 PM
Jutdees
06-27-2011 02:51 PM
khnt
06-15-2008 05:48 PM
bob53
01-17-2008 05:24 PM
