(Front) brake light problem
There is some slack in my front brake lever which causes my brake light to flicker or at times stay on. If I push the lever forward with my knuckles, the brake light stays off, but if I don't do this, the lever will eventually activate the brake light. It's as if the master cylinder plunger isn't pushing against the lever hard enough and not holding the lever completely open.
Any ideas before I frustrate the heck out of myself trying to diagnose this problem?
Thanks in advance.
Thanks in advance.
So I have this issue with my bike as well. The plunger slides in a rubber sleeve that dries out. When this happens the spring can't return the plunger far enough to disengage the brake light switch. You just need to lubricate the plunger. Do not use penetrating oil like WD-40 though. Use a silicon spray oil or something that is safe on rubber seals. You will eventually have to rebuild when the seal wears out though.
I'd strip and inspect your handlebar master cylinder first. When I did that a few years ago I was disgusted at what came out! On many bikes, including mine, the master cylinder points up a little, so the fluid doesn't flush everything out when being bled, hence 'stuff' can accumulate inside. You can get an overhaul kit which replaces all the essential parts inside
grbrown, While working to fix this, I had actually considered going the extra step to replace my brake fluid. After a period of time/miles, the viscosity and efficacy brakes down.
Since this is a new-to-me scooter, it would probably be good to put in new brake fluid while I'm at it.
rd
rd
rd
rd
woodster54
09-24-2012 08:50 PM
