67033-99A Speedometer connector plug
Does anyone know what the model number the connector plug is that connects to the 67033-99A speedometer? I'm going to see if I can make a custom harness that has the 67033-99A plug on one side, and the other, a DTM06-12S and DT06-3S so that the speedometer will work on my bike. I'm pretty sure all I have to do is figure out what each of the pins to the 67033-99a are, and designate each wire to go to it's appropriate terminals. I've put an 05 Roadking tank, with a full dash I bought on Ebay, on my 01 Sportster if you're wondering about the application. All I need is the plug for the speedo and I'm good to go. Or, if anyone has a diagram for this specific speedo, I could just directly connect the wire to the pins without getting the actual connectors. Anyways, I'd appreciate help.
Thanks
Thanks
rgb66
Electrical/Lighting/Alarm
07-21-2019 07:13 PM
