Home Made Tune
Location: Back in the Good Ole USA. South Carolina to be exact.
I'd like to offer my opinion. You are going to be wasting fuel if you are running richer than 14.4 in your cruise area. With your timing tables there are areas where it is possible to add enough timing to go past MBT ( maximum brake torque) and still not see knock retard. In the data shot you posted the knock retard is being generated a few frames before where the cursor is actually placed, probably around frame 456-57. To me that looks like it is where you have just wacked the throttle. Sometimes you can add a little in your ae table to eliminate that. Why is your data log showing the map in In. Hg. when timing tables are kpa? Could you refresh me on what your bike is and what map you are running?
You are correct running 13.8 in the cruise area is likely wasteful and hurting my milage. I had been thinking about this since Gordon's post. I probably will thin out the cruise range.
The bike is a 2008 Fat Bob, I am running the 176AE106 map. I have english measurements selected in the setup, that is why it doesn't show kpa. I can select these individually to shw kpa.
I have been looking at the TTS manual and following the strategy for adjusting the timing. So now that I have settled on 13.8 I am pushing the timing 2 degrees ahead until I get knock, and then back off that cell, and repeat the process. Your suggestion about adding in that area of the ae table is something I hadn't considered. Guess I was focused on following the procedure as outlined. Is it realistic to continue pushing the timing ahead expecting to be able to affect most cells this way?
At some point I plan to thin the cruise area back some. Certainly I'll need to back the timing off in this area when I do.
When you go leaner for the cruise range, you're going to get knock since you have added timing everywhere. This is going to make your bike run hot. It's going to knock and the computer will take timing away which will kill your power.
You are expecting too much out the the AFR table adjustments and should be working on the VE tables for open loop riding.
The AFR table adjustments are only useful in closed loop and those (AFR table) only come into play at ilde and at steady throttle openings.
If you are wacking the throttle while trying to auto-tune your bike, you are defeating the system. My understanding of the TTS auto-tune is that you want fairly steady throttle openings over an average of distance for best results. I pretty sure it says to set all the tables to 14.6 for auto-tuning and go easy while in auto-tune then reset it back to the original AFR setting afterwards. I always set my idle rpm settings richer (14.3) so it does not overheat at red lights but my cruise AFR tables are at 14.6.
The base map you choose should be selected by your cam choice and closest to your build/mods you are using. Those timing profiles should not have to be adjusted very far from where they are set. Depending on what pipe you are running, etc, you may gain a little here and there but just selecting all the cells and bumping them up is not helping you. You really need a dyno tune to be messing with timing tables.
I was following the procedure reccomended in the TTS manual, but I am not really satisfied w/the way it is working out so as I say I will likely go back to the base timing map.
Open loop is where your engine is operating off the VE tables.
If a cell in the AFR table is 14.6, then that area is controlled by the O2 sensors in closed loop. Any other values put that area in open loop and will depend on the accuracy of the VE tables to produce the desired AFR.
fuelmoto
Fuel Moto / Jackpot Mufflers
08-08-2018 04:39 PM
rwt
40
08-05-2015 07:54 PM
