Dynojet PC-V or TTS MaterTune
Hello everyone.
I have a PC-V on order thru Jamie at FuelMoto which should be shipping within the next few days but I'm really beginning to second guess myself. I should just pick up the phone and call Jamie but I thought I'd throw it out here first...
I'm really not a big fan of piggy-back systems as the PC is and I've been hearing more and more good things about the TTS MasterTune. I am looking for something pretty much "plug and play" as I know Jamie's programming is pretty much "dead nutz", but on the flip side, I'm not totally incompatent using a computer either. I really like the VTune feature of the TTS system, it seems a good feature to fine tune a programmed MAP.
Anyway, I was wondering if anyone had any thought's to help me finally nail down a decision.
Thank's in advance, Rich
Hello everyone.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Pcv - tts
Here is my take on it...
For a basic stage 1 and no future changes planned the PCV is a good solution.
If you plan on changing the bike in the future or have something more than a basic build, the TTS Master Tune is hard to beat. It is not an add on unit, is easy to tune, it has more features and options but cost a little more.
B
B
For someone not willing or able to dedicate the time and effort, I'd suggest they not invest in the MasterTune.
Hope that helps.
I cant agree with the PC's usefullness being primarily for a stage 1, as the PC V offers complete control of the injectors. You can make adjustments based on alpha-n (rpm x tps) and you can also configure them based on cyl head temp, speed, gear, or any 0-5v input. You also have a wide range of ignition timing adjustment. It also has input for a map switch to switch between 2 maps (any closed/open style switch will work, including the acc switch on many HD models) You also have the option of adding the Auto Tune module which allows for complete closed loop tuning. That being said I really like the TTS as well, and have dyno tuned many bikes with the SERT/TTS. We are also a TTS dealer. But for ease of tuning it is not a fair comparison between these 2 products as the PC was designed for tuning center/consumer use and SERT/TTS was designed as a "hands on" product for a trained Harley dealer tech with a chassis dyno and a complete understanding of Delphi ECM strategy, EFI lookup tables, etc..
Whether you use the PC V or TTS or any other tuner, any one of them is only as good as its tune and I would make your choice based on the amount of support available or your willingness to learn the product.
You can make adjustments based on alpha-n (rpm x tps) and you can also configure them based on cyl head temp, speed, gear, or any 0-5v input. You also have a wide range of ignition timing adjustment. ... But for ease of tuning it is not a fair comparison between these 2 products as the PC was designed for tuning center/consumer use and SERT/TTS was designed as a "hands on" product for a trained Harley dealer tech with a chassis dyno and a complete understanding of Delphi ECM strategy, EFI lookup tables, etc..
The PC maps have previously been alpha-n-ish as well, but in all cases, being piggybacked onto a MAP-based EFI makes the end result no less MAP-based, right? Is the 0-5V input suitable for use with a MAP sensor signal, and if so, is there a dither adjustment on it?
I used a PC-III for a bit more than a year / 16k-or-so miles and graduated to a TTS tuner. The end result is a fair bit different, really. It's nice having closed-loop operation again. I feel a lot more at ease with the feeling that a clogging injector or maybe a tank of really different fuel while on a trip will be addressed as well as possible instead of the alternative. And it really is nice not having the extra connection in the main harness along with some wire and a box all wedged into a small space anymore, though to be fair, I don't recall ever having a problem with either thing.
The extra latency inherent in a piggyback system never really seemed to be detrimental to me, either, but not having it added is a nice feeling, too.
Mainly, though, for me it's really nice having the Adaptive Fuel routine up and running again. The more I've learned about it the more I like it, and having it. Having to forgo it with the PC-III was really enough of a reason for me to switch horses, so to speak.
I've seen a price for the PC-V and autotune modules somewhere 'round here. Together, the price exceeds the TTS setup by a fair margin, right?
I'm wondering. Does the wide-band close-loop system use an AFR table based on TPS/rpm? How well does this work on top of the MAP/rpm base system? How often is it recommended to free-air calibrate the O2 sensors? Is this system intended for constant use or maybe more for generating "regular" maps?
Thanks.
Jamie, it seems as though the PC V is going to be as hard or harder to learn than the TTS now, if one plans to use all the functionality available in the PC V. Are all those schemes available together or is it more a list of individual choices? The "per gear" function sounds interesting, but I guess I'm a little puzzled how that feature benefits our bikes which don't concern themselves with anything beyond whether the "6" lights up on the dash or not. Does it offer multiple maps based on a comparison between the speedo and tach signals?
Thanks.
Thanks.
