Security Light
Security Light
Hi everyone. I have a 2006 Electra Glide Classic with the factory security system with 16K miles on it. While riding the other day I noticed the security light (red key) come on for a few seconds then went off. When I stopped and restarted the bike later on, I noticed that after the bike was running for 10 seconds and the securoty light would come on for 5 seconds then go off. Every time I leave the bike I set the alarm with the fob as well as disarming it. I really don't want to take it to the dealer unless I have to. My local dealer doesn't have a good reputation with repairs done right the first time. Any and all help is appreciated.
i found this on another site months ago and kept it.
For 2001 and up Harley Davidsons with TSSM Security Module, (key icon displays when key is turned to ignition position)
if your security light stays on for a prolonged period of time, if you have changed your battery or disconnected your battery when fitting components such as LED turns & if you have fitted LED turns without a load equalizer, you will need to reprogram your OEM Module.
text in red below step procedure is confirmation of action, always wait for confirmation before hitting the next step:
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
(see error code thread)
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
Thats it, TSSM is now reset
Smoking Gun 44
07-06-2019 12:01 PM
