Receive 25% OFF Arc Audio Kits today!!!!!!!!!!!
EASTERN PERFORMANCE CYCLES
ARC AUDIO MPAK 4 And 6 Kits 25% OFF
ALONG WITH IN STOCK ACCESSORIES
Mpak 4 Moto Speaker & Amp Kit
This is a complete package with 6.5 Moto speakers & adapters.
Includes full plug and play input/output signal wire harness.
Includes ARC Audios new MOTO 602 High performance coaxial motorcycle audio speaker
Kit Includes:
(1) KS125.2 Mini
(1pr) KS5026 6.5" Coaxial Speakers
(1pr) 6.5" Speaker adapter rings View PDF
(1) Motorcycle wire and installation kit
(1) Step by Step Installation Manual
Call in and receive 25% Off
Retail Price: $449.00
KS 125.4 500 Watt Amp
The KS125.4 Mini uses a patent pending auto sense turn on circuit that offers a significant improvement in reliability and operation. No more will the amplifier unexpectedly turn off in the middle of a song. Instead of relying on the music to thru the amplifier on, ARC Audio's new design detects the BTL IC (Chip Amp) used in the majority of stock head units and amplifiers.
Specs:
4 Channels @ 4 Ohms- 75 Watts
4 Channels @ 2 ohms 125 Watts
2 Channel @ 4 Ohms (Bridged) 250 Watts
Frequency Response 20Hz - 20kHz
Crossover Range 40Hz - 500Hz
Bass Boost +15dB @ 45Hz
Mpak 6 Speaker & Amp Kit
High efficiency non digital amplifier design works with the parameters of the factory motorcycle charging system
Speakers bolt directly into the factory locations with no modifications or changes needed to the speakers mounting area
Kit Includes:
(1) KS125.2BX2 Mini 2 channel Class H amplifier
(1pr) Moto602 High performance 6.5" high performance coaxial speakers
(1) Plug and play HD wire harness and installation kit
(1) Full color installation instruction manual
Retail Price: 699.00
6.5" Speaker Adapters
Get the benefits of a larger driver in your bike without having to modify your motorcycles factory speaker locations
Each pair of 6.5" adapter rings are made of compressed composite
Retail Price:$45.95
6.5"XDI 6.2 COMPONENT SPEAKER
2-Way Component speaker system
Reinforced injected poly cone material
Specs:
Diameter 6 1/2"
Power Handling (Peak) 240 Watts
Power Handling (RMS) 120 Watts
Frequency Response 55Hz - 20kHz
Sensitivity 87dB
IMP. 4 ohm
Retail Price:$199.95
** All Prices Subject to Change and Limited Quantity**
Links to our easternperformance.com site:
MPAK 4 - http://www.easternperformance.com/pr...Touring-Models
KS 125.4 500 Watt AMP - http://www.easternperformance.com/pr...Touring-Models
MPAK 6 - http://www.easternperformance.com/pr...Touring-Models
6.5" XDI 6.2 Component Speakers - http://www.easternperformance.com/pr...Touring-Models
CALL TODAY AND MENTION THIS HdFORUM THREAD! 410-451-5181
Kit Includes:
(1) KS125.2 Mini
Specs:
Kit Includes:
Retail Price:$45.95
Specs:
Diameter 6 1/2"
Sensitivity 87dB
IMP. 4 ohm
Brian W
Vendor For Sale Classifieds
05-30-2013 09:11 AM
