Magnum +8 Black Pearl Throttle and Idle cables
--->>>SOLD.
I have a pair of +8 Black Pearl cables - throttle and idle. I had these on my 09 Dyna for about 3 days before changing my risers out and adding a couple inches, so I had to change out the cables. These have less than 50 miles on them. They've been sitting in my garage for over a year since I took them off. They look "as new".
The idle cable is 44258 (Black Pearl number of the Chromite 34258). The throttle cable is 43258 (Black Pearl number of the Chromite 33258). You can check the magnumshielding.com site and "search by bike" if you want to verify the numbers are good for your bike.
These are $60 each plus shipping from Magnum. You can get these for $85 shipped. It also includes two new brass barrel connectors.
Actually, I can't tell since I don't have a set. In order to check, there's four approaches I would take (good for anybody looking to change out their cables). Lengths on the cables I'm selling:
43258 (throttle): Casing length 38-3/4", travel 5"
44258 (idle): Casing length 38-3/4", travel 4-3/4"
Approach 1: If you still have the stock cables on, test fit the bars and see how short/long the stock length is compared to these. You can use that add/subtract to get the total length and compare it to what Magnum shows.
Approach 2: If you don't have the stock cables on, but do know the length of your current cables, you can still do approach 1, but just make sure you use the numbers of your current cable to add/subtract.
Approach 3: Using thin wire (like telephone wiring), route the path you'd want the new cables to take. I would measure for the outer casing (making sure the travel length you need is the same as these cables). Make sure you include the preferred loop length out front to ensure clear travel when turning the bars.
Approach 4: If you're just wanting to replace the cables you have with this set, just measure the outer casing length and compare (assuming the travel length for your bike is the same).
When I search for 2008 FXCWC
Throttle cable that I get is 33258 this is good as per your above statement
Ide cable is 34258 whereas you say that Idle is 39258. Can you confirm
Thanks, shrini. You are correct. It is 34258. I can't even read my own handwriting. I got it right in my reply, just not in the original post. I've edited the original post with the correct numbers (same as those you have).
