2010+ Wide Glide rear fender painted denim black
I've gone to great length to keep this fender pristine. As you can see I think I did a good job. .not easy with flat paint. There are rub marks visible near the rear seat hole for the passenger where the solo seat rubbed. They will be hidden by any seat you use because I had a LePera Bare Bones, which is as minimal as they get.
This fender is 'ready to go' for a WG rear fender swap for a current Fat Bob owner with a black denim paint job. Even has the plastic tabs on the inside for holding your turn signal wires away from the wheel. Also has adhesive spacers. Will include the fender mounting brackets as well.
Paint was done by a local and has held up very well. Neither I nor my friend could tell a noticeable difference from the Harley black denim and the fender when it is installed on the bike.
PICS.
Asking $300 shipped to your door in the CONUS. Local pickup available (and preferred) in Northern Virginia/DC/Maryland area.
Thanks for looking,
Matt
Edit: Wanted to add I'll be selling some other parts that go well with the conversion. More pictures to come when I get time. Would consider bundling.
Front turn signals, which are 3 wired for run/turn/brake and have a healthy length of cord so you can easily get them to under the seat.
Stock run/turn/brake module off the 2010+ Wide Glide which the turn signals plug into.
Roto-Plate License plate Shown here in gloss black and axle mount.
PICS.
Thanks for looking,
Matt
craftsmandave
05-02-2012 03:37 PM
BigNick
12-03-2009 09:49 AM
