fxdx fxdxt wheels tires rotors and pulley
Is it dual disc front brakes
I think I see two rotors on the front tire, am I correct? Is the rear pulley 70 tooth? I am interested but need to confirm fitment to my 98 fxdl with stock 39 mm front forks. I know the axle is correct by wanted to make sure that the tire is not for the wide glide series as those front hubs do not fit my current stock front end.
Pinetop
Pinetop
Yup. Dual disc up front. 70 tooth pulley. Axle size is the same but 2000 and up used sealed bearings. Both wheels are stock 2001 fxdxt rear tire is mu85b16 slightly wider than stock super glide size but wheel width is the same. Hope that helps. Front hub is for a narrow glide front end 39mm forks
