S.E. 211 Cams mounted in the cam plate with oil pump
Screamging Eagle 211 cams mounted in the cam plate , with good tensioners and oil pump also, cams have 3000 miles and cam plate and oil pump have 10,000 miles all in great shape. just remove the stock cams and install this plate in, easy job. no press or maching shop needed.
150.00 includes shipping
E mail me at JohnCA58@pacbell.net
duh...nevermind looks like it is for mid upper and higher comp...
Still have these cams ??..i plan on doing 95" kit here soon..on my 03
dyna lowrider,,,w/9:5 compression..do you know how these will perform.i already have vh big radius exhaust and se ignition...and se
air cleaner kit...got laid off ...so trying to finish build for as little as possible..i almost have the $ saved up for the 95" kit....thanks so much...would you consider trading something for them ????????
Mail me at darylemmit@hotmail.com
Wow...these sound perfect if they would fit....would save me all kinds of $ in labor..again thanks daryl
rking1550
07-15-2016 02:01 PM
JohnCA58
08-24-2009 03:14 PM
