Patriot Defender 2 into 1 Black 2006-2014 Dyna
I'm selling my Patriot Defender 2 into 1 pipe. It is used and has the normal scuffs from the road. The heat shield has some rash under the bottom of the pipe from dragging when going right. However the rash is contained to the heat shield and is not visible when installed on the bike. This pipe makes good power and I think it sounds good. However I have just purchased a brand new D&D Fat Cat because I wanted something louder.
Also, I had the internal butterfly professionally removed as I never intended to use it and it was just a hassle. So the butterfly and associated shaft is not present.
Here is the MFR website:
http://shop.patriotpipes.com/m131910...l#.Vk-EhdKrTcs
Here is a video I took on my bike just a few weeks ago so you can hear and see it.
These pipes faired very well in the dyno shootout done by Hammer Performance and bested pipes costing twice as much. Here are the dyno results:
http://www.1250kits.com/ttxlexhaust.shtml
This is a good pipe and you can get into it cheap since its used.
I'm askingNo Longer for Sale
