V&H side shots on a 14 fat bob???
Old 08-29-2014, 08:57 AM
Echo5's Avatar
Echo5
Echo5 is offline
6th Gear
Default V&H side shots on a 14 fat bob???
Anyone tried to put side shots on a 2014 fat bob? I called V&H and they 'haven't tried it.' I cant think of a reason why it wouldn't work. Anyone like to weigh in on this...
Old 08-29-2014, 03:06 PM
Echo5's Avatar
Echo5
Echo5 is offline
6th Gear
Nobody?
Old 08-29-2014, 03:22 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Here is a pic, looks good to me although I like 2 > 1s for the power:
Old 08-29-2014, 03:27 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jeff's 1st Harley is offline
Will the rear pegs clear the pipes?
Old 08-29-2014, 04:37 PM
adm's Avatar
adm
adm is offline
Received 2,478 Likes on 1,415 Posts
Certainly looks like they do. Fugly pipes tho (IMHO). You'd be better getting a 2:1 for more performance rather than just sound and fury.
Old 08-29-2014, 09:40 PM
Mr Bentwrench's Avatar
Mr Bentwrench
Mr Bentwrench is offline
On the Sporty forums the Side Shots are not giving up all THAT much to the 2>1 pipes on the dyno. The trick seems to be the hidden crossover pipe unique only to their Side Shots. Popular style on Sporties but rare on Dynas. Huh.
Old 08-30-2014, 01:18 AM
DaBiggestOrc's Avatar
DaBiggestOrc
DaBiggestOrc is offline
Stage III
That pic from V&H is a 96ci, check the O2 size, it should be 18mm on the pipes, not sure if your Dyna went to 12mm in 2012> with the 103ci. Your V-twin with short pipes will benefit from quiet baffles in performance and sound. If you do not order the quiet baffles and install them first then you will have to remove the pipes again. The stock baffles are nothing more then a slightly smaller pipe inside the exhaust. (it's basically a wide open pipe from the engine exhaust to the pipe outlet)
For that style bike, those pipes match it perfectly. Bad a$$ brawler, No BS Fat Bob. Looks sick, sounds sick....just another opinion =)
Don't forget exhaust gaskets, air intake and a tuner. Damn it gets expensive.
Old 08-30-2014, 01:32 AM
Dyna_Syx's Avatar
Dyna_Syx
Dyna_Syx is offline
I wouldn't care so much about the pegs.
The big downer here is that it looks like you'd have to remove your pipes every time you wanted to check the oil.
Old 08-30-2014, 07:10 AM
DaBiggestOrc
Stage III
[QUOTE=
The big downer here is that it looks like you'd have to remove your pipes every time you wanted to check the oil.[/QUOTE]
The oil stick is hinged and there is no problem checking the oil. Assuming Harley has not changed the dipstick for 2014.
If you take out your dipstick, and it looks like it needs a Viagra pill then it will work fine with this pipe. =)
Old 08-30-2014, 07:23 AM
Jeff's 1st Harley
My big shots have that crossover pipe in them too.
Quick Reply: V&H side shots on a 14 fat bob???
