Install Smart Security System
I made the mistake of not ordering my 2014 Low Rider with the security system and I am looking to add it now. The dealer gets full retail at $360 but it can be bought online for under $300. The Harley web site says it must be installed by a dealer. Is this true? If I have the dealer install it I will have to buy it from him and the total cost will be high. The security system (41000087B) appears to be a simple plug in module.
Does anyone have any experience doing this? Is the module that the Smart Security System replaces easy to get at? Where is it located? Would an alternative be to buy the system online and have a local independent shop install it?
Thanks.
Thanks.
I bought my Street Bob used. Came with the HD security system installed (proximity key fob). I chose to remove the system and sold it on this forum. You replace your TSM (turn signal module) with the new TSSM (turn signal SECURITY module). It is located on the left side of the bike in the fuse case if I remember correctly. It takes less than a minute to install. You simply unplug the old and replace with the new. Route the antenna under the seat and your good.
HOWEVER, what takes a while is mating the new TSSM to your ECM. There is a a write-up on this forum how to do it.
Here's the jist of it:
Theres a sequence of turning the key and flashing turn signals. I don't remember what it is but once you do that you leave the key in the "ON" position with the bike not running and set a timer for 10 min. At the 10 min mark, a light will flash on the dash and you turn the key off then on again. Wait another 10 min, then do same thing, wait ANOTHER 10 min and then complete the sequence. New module will be synced to ECM.
This same sequence has to be followed to remove security as well.
https://www.hdforums.com/forum/elect...roceedure.html
I sold my unit and key fob for $100. Look on ebay you might be able to pick one up.
It would literally take a thief more effort to overcome a bicycle cable lock on your front wheel.
So, an electronic security system is definitely worth something.
Received 2,199 Likes
Love mine.. the fact that I never have to take my keys out of my pocket is nice. Just sit and go...! No fumbling around.
i just did the kit about a mount ago. paid 150 on ebay for a spanking new kit. paid dealer 90 flat to install after giving up on DIY.
full kit:
http://www.ebay.com/itm/Harley-David...item280f21db86
i tried to DIY. frustrating and not worth the stress. the pairing can be done at home, but you'll need to roll to the dealer for fobs.... it's bs and not cool for hd to do that, but that's where S*** is.
listen for chirps when bike is turned on and off. the alarm will go off if jostled, moved, or uprighted.
i would do it. it's great not having to key your bike. just have the fob on you and you are good
c'mon man
- https://www.hdforums.com/forum/dyna-...m-install.html
- https://www.hdforums.com/forum/dyna-...l#post14550987
full kit:
I didn't get one either but I didn't see much benefit to be honest. Maybe I'm mistaken but doesn't it just shut off fuel? It prevents theft only if someone wants to ride it away after breaking the fork lock & hotwires it?
