1993 FXDWG Fuel Tank Vent Question
My 93 FXDWG has what appears to be a small vent hose connection with a rubber hose on it on the top front of the fuel tank under the dash. The hose goes from the tank to a small black plastic canister about 3/4" in diameter and from there disappears under the fuel tank.
Is this a vent hose connection? What is the small black plastic canister for? What would be the consequences of the hose or canister being stopped up or leaking air (I have no fuel leaks)?
Thank you!
Thank you!
