wobbles
Old 07-15-2014 | 01:42 PM
cerelious's Avatar
cerelious
Well well well...put it up on the jack ran it, and had my wife look at the tire. She said that the tire was tilting at an angle (especially at high speeds), looked it up in the manual, said to adjust the stabilizing link, and I am missing a bolt in the stabilizing link!!
So after I get the bolt and get that set right, the manual says to use an inclinometer to compare the rear brake disk to the front....lol looked up that tool, that's a lot of money!! Do y'all just eye ball it or what? Thanks for all the input and ideas! I like it here, a good group of people
Old 07-15-2014 | 03:18 PM
4_stroke's Avatar
4_stroke
A digital angle gauge is cheap from ebay. You could also use a spirit level on the disc as a cheap alternative. Another thing to check is if the front mount is soaked in oil. If it is it will go soft alow the motor to wobble sideways.
Old 07-15-2014 | 06:03 PM
BMyers's Avatar
BMyers
Harbor Freight has some cheap inclinometers. Buy 2 swap them front to back and average the reading to offset tool measuring error.
Old 07-16-2014 | 12:09 PM
cerelious's Avatar
cerelious
Well got the bolt, installed, and eye balled, road tested to 95, smith sailing!! Going to remove tank and torque it to spec today to make sure it's solid. Thanks for all the advice!!! I can't believe the shop didn't think to check the stabilizer
SportsterSnow
08-15-2012 08:20 PM
ia2189
04-05-2011 01:06 PM
harleyrunner56
09-16-2009 03:53 PM
joeld0803
02-01-2008 06:08 PM
Scott58
04-23-2007 12:21 AM
Quick Reply: wobbles
