wobbles
Sorry super glide custom (07) just got back from the shop that did the job, they check the tire and balance (half ounce off) but that wasn't it. The shop said that it doesn't make sense since everything on the bike is in spec except the steering. That was the only thing that they found that isn't "right" he said it's to tight and that the neck bearings might have gone bad and that that migot be the issue. Thoughts? I have never done the neck before, what am I getting into? I'm a quick learner and fairly handy
Not sure about the too tight. I have always adjusted the bearings to the tight side of the fall away. I personally don't think they were too tight to the point of failure. Maybe check your fall away and see where it lands. IMO it still sounds like a tire issue. What brand did they put on?
I got the Metzler ME 880 Marathon. At slow speeds (60 and below) in rides like it did before, except with these Metzler I can corner like a freaking champion!!
I decided to take a more objective ride and when it starts wobbling at speeds, it's almost like I hit a giant tar snake, like it wants traction, except it's scary, like I think to my self, so this is how I wreck. Back off the throttle and let it get to about 60 or 55 and it stops but get back up to speed and it comes back
Did anyone from the shop test ride it to see if they can feel it too? Also check to make sure they got the balance dots on the tire ( should be two red paint dots ) aligned with the valve stem ( just another thing to eliminate ). Are you running spokes or mags, dont believe I saw where that was mentioned.
