Enrichner Cable
RE: Enrichner Cable
I'm not sure if this will help,but here goes. A friend of mine had told me not to use the enrichner, but just get it started and have the throttle brake after the idle up a little. After the engien has warmed up, just let the throttle nbrake off and get going. My wife has been doing it since she started riding.
RE: Enrichner Cable
What Soup48 said. In addition I only use the enricher to initially start the bike if the temps are in the 30's then push it in all the way immediately and set the idle at about 1500 rpm for about a minute then take off. Above 40 degrees I never use it. The way I see it using the enricher at all after the bike has started is only going to cause increased chances of fouled plugs.
