Street Bob rear tire options?
you can get a 200 to mount on the stock 4.5 rim but it will be ballooning and bulging and the beads will be questionably seated..., minimum "safe" rim width recommendation is 5.5 for a 200 ... I play it safe rolling on asphalt on 2 wheels... im running a 6 inch crossbones wheel
which 180?
I have a 2016 SB and want to put a 180 scorcher on it. The harley parts guy won't give me a straight answer which tire to get. . It looks like there is a 180/55, 180/60 and 180/65. I'd prefer the RPM's and everything stays the same so which is the right tire?
I lowered the back with 11" progressive shocks if that make a difference?
Thanks,
Thanks,
Not Really, the kit just changes the turn signal wiring position inside the fender with different brackets,, making sure they're tight to the inside of the fender,,
You can do the same thing with Duct tape.
Well he can't,, he's not a mechanic or the bike owner,, he has to recomend the listed tire for the bike. He'll sell you what you ask for but he can't advise you.
Like mentioned by someone else I went with the Pirelli Night Dragon 180/60 and it's a hassle free drop in,, it's been a great rear tire too!
jfretire (11-19-2016)
