Broken exhaust pipe
Broken exhaust pipe
Yep you read it right. Bike been sounding funny, Idling weird for a few days. Finally found out the rear exhaust pipe was cracked. And by cracked I mean it was barely hanging on. I pulled it the rest of the way off by hand. I been wondering why it's been idling like crap lately and feeling sluggish. My SE II mufflers have no baffles but it's amazing what letting some exhaist out somwhere else can do. These are the original harley pipes too.
This all came from the PO not installing the bracket that supports rear muffler and keeps it from wobbling. I made appt at local shop to have a new bracket installed tommorow morning but looks like I won't be needing it now. Just going to buy a quality set of after markets and will a good exhaust my engine will run better hopefully.
Being tight on cash the Vance Hines short shots are looking real good for me. I like loud and I've heard you don't loose to much bottom end torque when leaving baffles in. If I did loose a little bottom end I probably wouldn't notice.
So if I buy the short shots do you think I should take the bike in and have the carb tuned to run right with them?
No its from not having the proper bracket to support the rear muffler. When PO installed the Screaming Eagle mufflers he didn't re install the support bracket. Its been shaking up and down for awhile and i had a appt with shop to get a new bracket on there. Unfortunately it gave out 12 hours before my appt.
No warranty left on a 2002 lol
I had a similar thing happen to me a couple of years back (2011 FXDB) - cracked clean through the rear pipe, just behind the O2 sensor. Scarcely a year old, all standard mufflers etc, never taken off the bike that I'm aware of.
Luckily, local HD replaced it under warranty, no quibbles. Even touched up the paint where the loose end of the pipe had scratched the swing arm.
It made me decide, when I changed my pipes, to go full system (V&H Straightshots) rather than slip-on...
Harley1016
2014-2023 Touring Models
17
09-18-2019 05:22 PM
HyperM3
06-03-2013 08:04 PM
