Polyurethane Motor Mounts for Dyna
Old 05-01-2014 | 08:53 PM
rooti's Avatar
rooti
15 years ago. Lived in Santee, El Cajon, Lakeside area most of my life. My wife was raised off of twain ave. off of mission gorge rd.
Old 05-01-2014 | 08:55 PM
br549A1's Avatar
br549A1
_____
Old 05-01-2014 | 08:57 PM
FXDLXSD619's Avatar
FXDLXSD619
6th Gear
I know where that it.
Old 05-01-2014 | 09:00 PM
FXDLXSD619's Avatar
FXDLXSD619
6th Gear
I have a sputhe as well that I've had prior to the new mounts.
Old 05-01-2014 | 11:02 PM
Loner88's Avatar
Loner88
2 new for their website, apparently http://www.glide-pro.com/index.html
Already run a Sputhe, so doubt it would buy me much in terms of better handling; albeit, if I didn't, would be something to consider. Questionable on the decrease in vibes compared to rubber, from what I've read on bagger forums. Got any links to reviews by peeps riding with them installed?
Old 05-02-2014 | 07:51 AM
mattVA's Avatar
mattVA
Sounds like these are targeted toward drag racers? Seems like they'd give a firmer ride with more vibes. Anyway curious to hear some reviews.
Old 05-02-2014 | 09:22 AM
DesertDyna's Avatar
DesertDyna
Polyurethane will not decrease vibration. Thats not really its purpose. It is for better handling only. The only way you MAY see a decrease in vibration is if you have a failed stock mount, and you replace with the new one... The poly mount will eliminate the need for a Sputhe/True-Track stabilizer. On the flip side...the Vibra Technics mount gives you reduced vibration (because of the more rubber-like elastomer), and the handling (lateral stabilizing link).
However, if my REAR mount fails...I will definately be buying one of these....and eliminate my REAR Tru-Track stabilizer. Heck..i may just get one anyway...just to get rid of the rear stabilizer.
Old 05-02-2014 | 09:26 AM
br549A1's Avatar
br549A1
Aren't skateboard wheels made from poly? That stuff is hard as hell. The vibra-technics mount is really a great option.
Old 05-02-2014 | 09:52 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Wonder how the Poly rear mount would work with the Vibra Technics mount.
Old 05-02-2014 | 10:08 AM
DesertDyna's Avatar
DesertDyna
Thats what I intend to find out.
Quick Reply: Polyurethane Motor Mounts for Dyna
