Pop on Decel: PCIII Settings?
I've an '06 FXDL fitted with 8 deg injectors, V&H BSS c/w quiet baffles, TP Eng's Scramjet filter, and a PCIII with map 811-003 i.e. BSS + SE air filter, however, it pops like crazy on deceleration! Does anyone have any tips on what adjustments I can make to smooth things out, please?
RE: Pop on Decel: PCIII Settings?
Nice looking machine.
Not sure if this may apply but I had the same issue after modifyingametric cruiser I had with new aftermarket exhaust, air filter and PC III.
Turns out with my metric cruiser, is that there is a component that lets fresh air into the engine upon decel to burn up any unused gas to help limit emissions. I believe it was described as the air induction system or something to that effect. The pop or backfire was actually supposed to be happening, I only noticed it because I had swapped out the stock exhaust which had been muting it. The fix for my bike was very simply to block the system that brings in that air. And since it's only used to burn up that spent fuel, it does affect anything else, so disabling it doesn't cause other problems.
I'd suggest finding out if HD's have that same emissions system or set up.
ORIGINAL: Babe
Putting 0's in from 500-1500 RPM
At 1750-4500 RPM's put the number 15 in the boxes, again,,in the 0% column ONLY.
Run the bike...see if it's better.
If it still pops some...change the 15's to 20's....
Run the bike....
If the pops are gone,,,you can go down one number at a time now...to 19....
Run the bike...no pops? Go down to 18...etc..until the pops return, then go back up..one number.
