Bigger rear tire using stuck?
Old 04-19-2014 | 02:38 PM
Raven1482's Avatar
Raven1482
Default Bigger rear tire using stuck?
I got a 2012 dyna super glide (FXDC) it uses a 160-70-17 rear tire, so I was wondering, using all the stock parts, can I use a 180-70-17 tire?
PD
I do have a detachable back rest for the passanger, so I did move the lights
Thanks
Old 04-19-2014 | 02:50 PM
dirtdobber's Avatar
dirtdobber
How wide is the rim?
How much clearance do you have between the tire and the belt or anything that may rub?
All you have to measure is the one place that it is narrower.
Old 04-19-2014 | 02:54 PM
blueangel73's Avatar
blueangel73
HD makes a 180 tire kit for the Dyna, it's a180/60-17, I would guess that the 180/70 is only 5mm (.20") taller or 2.5mm (.10") larger on the radius. Either way I don't think its an issue, many people here have done it, using the detach fender bracket (in the link, you can order them by themselves) helps a lot to eliminate clearance issues.
http://www.harley-davidson.com/store...-12-4376806--1
Old 04-19-2014 | 03:44 PM
stilup's Avatar
stilup
Using a 170 is a good compromise.
stock rim.
Old 04-19-2014 | 08:45 PM
Raven1482's Avatar
Raven1482
I think that I bought it last year, I need to double check (I got it becuase I set the "One-Piece Detachable Sissy Bar Up right" and I had to move the turn signals and I remember those metal parts show in the link sent by you.
This is how it looks like right now
This is viewed from the top
I gonna double check, thanks
PD
Man, great job on your bike, I saw that Cycle Visions sells the Dyna-Baggertail Saddlebags but that is really expensive :S
Old 04-19-2014 | 08:59 PM
blueangel73
If you have the brackets already via your detach / turn sig relocation kit you should only need to mount the 180 tire. You could always get the actual width of the tire and compare it to the space under the fender.
I didn't go with the CV kit for my bags, to much money. I think I might have $500 in everything all together. I modified some touring bags, trial and error process, ABS is great until you want to modify it by cutting a big hole in it and reworking it.
Old 04-19-2014 | 09:01 PM
Raven1482's Avatar
Raven1482
I still had the boxes, I did install this Docking Hardware kit
http://www.harley-davidson.com/store...g-hardware-kit
Do you have pictures of your windshield? I have curiosity of what you did since I see some black parts
Old 04-19-2014 | 09:21 PM
Gommee's Avatar
Gommee
Devil's Advocate
I have a 180 Pirelli Night Dragon, they are made for the Harley rims. The detach hardware kit should do it, because it takes place of the stock nuts on the inside of the fender. I used aluminum foil tape to hold the wiring against the underside of the fender just to make sure there was no contact with the tire.
Old 04-19-2014 | 09:54 PM
latrobedyna's Avatar
latrobedyna
i have a 180-55-R17 Road pilot 3 on mine and i never used that silly kit and yes i have bottomed out the rear springs as well and never had any wiring issue. However the handling was greatly enhanced i feel with the lower profile radial tire.
Old 04-20-2014 | 06:53 AM
jmpancoast's Avatar
jmpancoast
Biggest problem I ran into when I went with the SE180 was the turn signal wiring. Have since gone with touring lights so its no longer an issue. Protect the wiring and keep them tight to the fender and you should be good.
Here is what the hardware from the "Wide Tire" kit looks like:
richbob
01-19-2023 09:46 AM
zio
08-03-2008 09:27 PM
fiftyonefive
02-07-2008 10:01 AM
ggibson
01-18-2008 05:37 AM
fl_799
05-03-2006 04:14 PM
