oil level
RE: oil level
Mine usually takes a full three quarts in theengine whenever I change it which puts it right where it should be when cold. If you dont have a manual for instructions on oil levels, be sure to check engine oil with the bike resting on the kick stand, and for checking tranny fluid levels the bike should be upright and level.
Hope this helps you out.
